Dropbox
Joe_Carrick
I have all my Chief Projects in a Dropbox Folder.  This works well for me as I have 3 different computers that I use and I'm always working on the latest version of a Plan and/or Layout.
I'm considering placing the Chief Data Folder (Library, Templates, Scripts, Toolbars, Hotkeys, etc) in Dropbox as well.
Has anyone else done this?  Other than having to change the location in Preferences would there be any problem?
I've had the Data folder in Dropbox for years without a problem. (At least that I know of.)  It's nice to be able to update the User Library and any Hotkey changes, etc. to all computers at the same time. Dropbox is fast enough that it can sync a large User Library very quickly; I believe some of the other services like Drive, etc. take significantly longer.
Mike, the Data Folder is just the user modified data. The core, bonus, and manufacturer libraries are still on the main hard drive.
You guys should keep in mind that Dropbox simply sync's the files to your local drive.  In the background it is just creating a copy on their server, which then allows other computers to sync with the updated files.  Its basically an expanded version of Microsoft's old "briefcase".
So you aren't working "on" Dropbox and so its just a set of local files like anything else....so it should work perfectly fine.  There are some settings where you can change this, but I bet 99% of people who use dropbox keep the settings default.
2 minutes ago, javatom said:
Keep in mind that syncing is not the same as backing up your data.  If you accidentally delete a file, it will be gone from ALL your devices.
This is a great point and has been discussed before.  So Let's talk about it again.
If you delete it from computer #1,  it is deleted from all computers...  correct?
Okay, if I delete it from computer #1 on Monday,  it is gone from all computers....  but...  but  ...  but....  on Tuesday I realize I deleted a file that is now gone from drop  box and all computers...  so how do I get it back?  If I have paid a little extra for something that DROPBOX offers which I believe is called PACK RAT,  can't I contact DROP BOX and restore files that were on the drop box on the previous Saturday.
I had just asked this same question in another thread. However, I was wondering if it would work the same as Carbonite.  It too is an instant backup to their server and not making a copy to your PC drive somewhere. it also keeps several ( I think up to ten) system mirror images.
I use, and love, DropBox and also have Carbonite that backs up my DropBox folder. I have 3 computers but only use 2 regularly. Every time I open my Lap Top Drop Box loads all the changed files onto the Lap Top and I have what is essentially another back up file. If I delete a file Carbonite will save it as Perry said for later retrieval.
There was ONE time I used Carbonite to retrieve a corrupted file and it saved me HOURS of re-doing a Chief plan/layout file. So I don't care how much it costs, that one time made Carbonite totally worth it. And for $50 - $60 a year? Incredibly cheap insurance.
Anyone else use both?
3 minutes ago, Richard_Morrison said:
Dropbox keeps an archive of all files for even the Free version for 30 days. If you upgrade to a Business account, as I understand it, it will keep a history of unlimited number of files for an unlimited amount of time.
Did not know that. Perhaps making Carbonite redundant? I'll check in to it. Carbonite is a deal and like I posted saved my bacon one time.
https://www.dropbox.com/en/help/296#event
What I can tell you is that Dropbox is really, really fast. I recall that Carbonite used to take DAYS to back up a hard drive, and afterwards it is faster. I don't know anything about the technology, but at this point, I can tell you that although the initial sync might have taken a minute or two, my 1.4 GB User Library now completes syncing in a few seconds, if I make a change.
What I have done is that I have Dropbox, but I also have OneDrive that is apart of my MS Office subscription.  So before I leave ( I try to everyday, but typically Mon/Wed/Fri)....I just copy everything in my Dropbox and copy it over the One-drive.  I didn't like using One-drive so that is why I went to Dropbox, so I figured, since I had the space on One-drive, use it as a backup.  That way if I accidentally delete a file on Dropbox, I can retrieve something from One-drive.
I personally use DB and Carbonite. I've used Carbonite for years so I don't even notice any time it might take to back up a new file and can't find a reason not to have some extra insurance. I'm not sure I have my User Library in my Drop Box folder. I'm going to check that out and see how to get that done.
We happen to use Sugar sync for our projects, it works well and updates automatically.
I think I read somewhere that CA should not be used on a server or connected over a network. Maybe I'm mistaken or meant not to load the actual program there . However, would using , placing the data file folder, user library  (not the program) into Dropbox, any other "online" service or a NAS drive be verging on that?  Would be intrested to hear if Dan had any input.
I seem to remember that also. Not sure if they fixed it or not
Yes, they did say this. But as Johnny mentioned above, Dropbox isn't providing data off of a server or network for DIRECT use in your system, All of the data that Chief uses is coming off of your local hard drive.
