Centering Text - Escapes Me ?
lbuttery
Ok, I don't understand how to center this text
vertically and horizontally ?
I see the marker bars but when I select them
it shoves the text all the way to the bottom or to the side ???
I'm sure there is a way to do this but ???
I'm using X6
Lew
Lew, layout pages are probably the single most difficult place to use the center objects tool. You just have to very slowly move your mouse across down at the bottom or top until you get a VERTICAL marker. Do the same thing on the side until you get a HORIZONTAL marker. When trying to center on a layout page those particular markers only show up when you're in just the right spot it seems.
Great advice Michael, can you here an echo...
It just seemed pretty clear to me that Lew wasn't understanding that he was using the wrong "center line" which is why I stressed the importance of using the lines that show up in the correct orientation (perpendicular to the side you're trying to center on).
