Cornerboards on bay window?
Christina_Girerd
I'm working on an older home that has the equivalent of corner boards on it's bay windows.  The cornerboard tool doesn't seem to work in this situation, so wondering if there are any suggestions aside from just using polyline solids?
This bay window is angled, but I also tried the tool on a squared bay window just to see if it was the angle that was the difference - didn't work on those either, so I'm assuming the tool was only designed to work on regular wall corners.  Sure would be handy if that tool did work in this situation as it is such a quick help on regular corners.
