Can you flip corner cab door direction
dshall
I know this is too simple, but I just copy/ reflect about. Not sure I understanding what you want b/c I know you know this. I did not do the floor overview.
That is the answer...  of course you now to to rotate the new cabinet 180 degrees in  plan view.......   the point is with most cabinets you can change a door from a right cabinet door to a left cabinet door.  With the corner cabinet,  you can not do that........  seems like a very small loss of function.
Scott,
You are correct, it is too simple!
Open the dbx.
Front/Sides/Back panel.
In the preview pane select the door by it's hinged or right hand side, NOT the handle side.
You can't select the door by selecting the handle or left side.
Make sure "2 Door - Auto Right" is selected.
Change Item Type to "Door - Auto Left".
http://screencast.com/t/C8l7Pwvc9hI
Scott,
Open the dbx.
Thx, I will give it a try.
