Foundation issues
Designer100
I would appreciate any help. Garage(plate stays same as house with high ceiling) needs to be 24" off grade with CMU Walls for flood plain to btm of house floor jsts. (automatic vents or break away walls.. Then house pier and bm at 54" finished floor off grade which is 36"+- above garage/stg slab.
All house is pier and beam (designed by engineer).I do not know why I cannot get house to show pier and beam all around outside etc. deck by media room and garage is surpose to be hip roof. I will have steps down to garage driveway.
Thanks,
I swear,  it just cracks me up,  why don't you make it easy on people and post a plan with a note explaining your issue.  I don't even know why I am responding to such an inane post by you.
It just cracks me up...  sorry for the rant,  but you are wasting people's time .
Pier and beam as in 'grade beam', which is a concrete or cmu wall sitting on grade with
concrete piers into the ground spaced per plan ?
You can make a blank foundation plan, draw a foundation wall, remove footing, and place piers from
slab menu. That will then show around outside in 3D views etc.
Elevation info not making sense so post plan or thumbnail picture.
