Tile on layout
crazytrajan
Go to solution Solved by Joe_Carrick,
  • Solution
If you have those in the Plan and/or Elevations, they will be in the Layout.  It's a matter having a material that has an assigned "Pattern" rather than just a "Texture".
Patterns are "Hatch Patterns".  There are many available in Chief as well as others from external sources that can be imported.
