Exploring Ray Tracing – Global Illumination - Compute Caustics
Rich_Winsor
So there it is, that enigmatic little check box under Photon
Mapping called “Compute Caustics”. What is up with that?
Should I check the box? How does it affect my ray trace?
If we consult Chief’s help file we get the following information:
Global Illumination –
> Check  Use Photon Mapping to accurately calculate bounced
lighting in a scene. When unchecked, ray traces have low quality
lighting effects but generate more quickly. Use Photon Mapping
should be checked for all interior scenes and unchecked for most
exterior scenes.
> Check Compute Caustics, to use caustic photons, which are
photons used in areas of focused light. Caustic photons are helpful
when modeling certain effects as light shining through glass.
Digging a little deeper we find this in the dictionary definition of
“caustic”. Aside from the more familiar meanings of the word
there is also this reference in relation to optics:
of, relating to, or denoting light that is reflected or refracted by a curved surface
Wikipedia expounds upon this further:
In optics, a caustic or caustic network is the envelope of light
rays reflected or refracted by a curved surface or object, or the
projection of that envelope of rays on another surface. The
caustic is a curve or surface to which each of the light rays is
tangent, defining a boundary of an envelope of rays as a curve
of concentrated light.
Taking all of this into consideration I created a simple scene
where the warm glow of the late afternoon sunlight streaming thru
a window highlights a pair of vases and casts their shadows onto
the wall. (How do I know it’s the late afternoon sun? Because I
never see the early morning sun (unless I’m recovering from an
extremely long night))  :)
This should meet the criteria of having a source of focused light
(the sun) shining thru (being reflected and refracted by) a curved
glass surface (the vases) and projecting onto another surface (the
wall).
FYI, the scene I created to demonstrate the effects of computing
caustics consists of 6 elements (a window, mirror, side table, place
mat and 2 vases). Everything in the scene is stock Chief content
from the Core Catalogs. I did replace the side table top with one
I created with a more realistic edge molding (Chief’s top had a
lame 45º bevel for an edge molding). The place mat is an oval rug
set to 1/16” thick and given the material of linen fabric. The vases
are 2 different versions of the same vase. I just changed the sizes
and colors and changed the Material Class to Transparent. To tie
things together I used the Rainbow Tool (Adjust Material Definition)
to get the color of the place mat and then used that color for the
walls. And then there was a lot of tweaking of the Sun Angle to
get the light in all the right places.
So what can we learn from all of this? Keeping in mind that we
are talking about very subtle effects here, let’s pull a couple of
ray traces and see what we get.
Both ray traces are identical in every respect save for the fact
that the first one is using Photon Mapping without computing
Caustics and the second one is using Photon Mapping with
Compute Caustics turned on.
I believe you will see that the answer is written on the walls.
Without Caustics (below)
Caustics%20Off-50%20Passes-44-66-60_zpsd
With Caustics (below)
Caustics%20On-50%20Passes-44-66-60_zpsqy
Rich - Excellent explanation and examples. The effect can be subtle but often it is these little things that brings a scene together. I find that the compute caustics can have a more profound affect when you have light fixtures where the bulb (light source) is behind a glass covering and must travel through the glass covering in order to light the room.
One note, you may need to up your pixel size in order to fully appreciate the effect. Will take longer to raytrace but the wait may be worth it.
Graham
Good call Graham. I doubled the pixel size and sure enough it
picked up some details that weren't present at the lower count. :)
Caustics%20On-Alien-5-100%20Passes_zpsxj
