Blocking/Bridging disappearing after adding openings(doors, windows)
daveaston
That's the way it works.
When you build auto framing, any manual framing work gets deleted.
How would it work if your manual blocking remained while the rest of the wall framing changed - your blocking would not be correct anymore?
And you can only auto generate 1 row of blocking at mid wall height.
