Change Glass Material in Window, Doesn't Show.
Anna_Gorres
Go to solution Solved by rlackore,
Hello all,
Rich, My"Opaque Window Glass" box is unchecked. Any other ideas?
DS Hall, I've inserted some photos. The glass around the center door needs to be a white wood panel. For the other wood panels I'm using a window treatment of raised wood paneling. I thought this would work, but it will not. For one, the wood paneling will not cover the entire length of the windows that plank the door. For two, they show perfectly to the clients current conditions (very slim molding/frame) on one side of the wall, but on the opposite side, they show a thicker molding which is not true to the current design (we are adding a few windows and acoustic panels, but not changing this area of the wall). I guess my other option is to use a 3D molding, but with how easy CA is suppose to be to use, I thought their would be an easier solution.
Thanks much, all!
Anna
