Stair landing and adding railing
ChiefuserLarkin
What's the trick to adding a railing to a landing? Either it puts it on the basement floor or on the main level.  Also, when I add a wall under the steps that follows the steps it wipes out the custom hand railing and vice versa if I do it the other way.  Any information would be appreciated!
Thanks!
Jason
Awesome, thanks!  That was easy enough. How do you change to a glass panel railing?
 Another issue, when I draw in a custom railing to follow the stairs, the wall below will wipe out the railing when I move it out to align with the stairwell.
Thanks a lot for the help! Appreciate it!
